Dr Crankenstein
I was happy to find it was a 1/2 ton 54! now I have a complete front clip for a 54, maybe that baby coe I keep talking about.
Don't tease, joe!
There seems to be alot going on in that mind.I need to read your mind...
Say hello to "Stumpy"
hahaha thats great, is that a photoshop or did someone actually build that cute little thing?
If it hasn't been done, it should be.
[P <----> [P <----> [P <----> [P <social distancing>
Arm-chair designer time. [ddd
Joe, your idea is a beauty, but it has been done many times.
I am not surprised that you have thought it out already. I love mental exercises like this. Can't wait to see what comes out of your shop (mind) next.I have seen a lot of coe turned pickups with a bed, but the front fenders dont match the rear fenders unless they make the rears much larger. I have also seen coes with big truck front fenders with the bottoms cut off too, but the large wheelarch. all of them are too big to fit in a std 7 ft garage.
I havent ever seen a 1/2 ton front on a coe. can you show me one? or many? I only have the side view to go on, it would be helpful to see a 3/4 view with the narrow 1/2 ton hood. like I said, coe parts are expensive, so using a shortened and taller 1/2 ton hood would be unique, at least I have never seen one.
believe it or not I have solutions (at least forethought) for both the door hinges and the hood. and also the hood hinges, on a coe they use a fence hinge at the top, mine would still hinge and open like a 1/2 ton.
If I was closer, I'd say stop over and pick up a pair of bed sides. I have two setsand a bunch of pieces. I was going to cut them into shorter beds for bobbers. I may still do it. Maybe take orders for specific sizes.thanks!
yes, my thought process was, use as many parts as I could to keep the fab to a minimum. keep the 116" wheelbase because it has to fit in my garage, I am an AC baby.
so the V6 and trans will be in its original position, not moved back 7.5 inches like I normally do, but an e fan will be needed. I also considered a OM617 mercedes turbo diesel and auto trans for that clackity clack.
the bed will be a standard AD long bed. I actually found one NEXT DOOR to my shop, couldnt see it till they mowed, still waiting on word if they will sell (not too hopeful given his attitude on the land)
the running boards can be standard longbed AD running boards too.
a std coe stands about 14" off the frame on a big table-legged style bracket, take out the 7" that mine will be lower and that means 7" taller brackets, but I also lower my trucks 3" with springs and so if I just lower the front clip and bed I can build mounts that are 4" taller and keep the "on stilts" look to minumum. mounts will be thicker and boxed though for sure.
I am thinking a very small trans tunnel for the distributor, change the angle of the steering column and of cooooourse all the door and hood fab hahah. like skip says "see how easy?"
