Nice call on the latches.[cl
[P [P [P
[P [P [P
looks good. Those tanks have many uses and most are dirt cheep[cl
[cl [cl![]()
Never thought about using a VW bug tank. I'll have to file that one for future reference.
[P [P [P
Good heavy gauge steel, and NOT galvanized.It worked out really well. Only has a capacity of about 10 gallons or so but I may add more capacity to the bottom still. I was really surprised how easy it was to weld on.
Finally started work on the trunk this morning after work. The upper most piece I will have to scrap as I forgot to account for the trunk being wider at the front and narrower at the rear. The rest of it will work but in order for the sides to fit proper I need it to go wide at the top to make up for the difference. I still need to roll beads in the upper floor but I’ll do that tomorrow. Once I have the beads rolled I can start tacking all the pieces together and then work on the sides.
Looking good! Are you going to make any of the pieces removable for easy access to the upper coilover bolts?
You could use DZUS fasteners and then it would be quick and easy to remove when needed.
Looking really good. [cl
I don't about your place but when I bought some Dzus for the sprint they were like 12 a piece
Machine screw are much better [S
Good luck with it and can't wait to see it on the road. [P
