sgtpontiac
Older, Wiser and Still Buildin'
If nothing scattered...i.e. hard parts...
then you probably would be safe draining the converter out...I'd catch the fluid and check it for particles (other than normal stuff you'll get) if you only see fluid, you probably will be ok...my guess is it burned some clutch discs and maybe a band....727 trans or 904? either way, discolored fluid normally is sign of disc or band wear....JMHO....you can turn that converter upside down and let it drain out.....will get the majority of the fluid out that way, just takes a bit..like hours ...
Picked up a rear seal and shoved it in the tail housing today. Went to put the torque converter on and smelled the burnt fluid. That got me thinking.... I'm gonna suck out as much ATF as possible from the converter. Do any experienced transmission guys here on RRR think that is sufficient? If not, what do you recommend?
