smallfoot
You're a true craftsman!
Looking good! I don't recall if you told us, does the battery box vent into the fenderwell?Made up all the interior panels to be upholstered from 1/8" ABS, more expensive than thin wood panels but doesn't crack or shatter when installing clips, etc., won't absorb water or rot. Bunch of smaller pieces go above the doors and front window, door tops.
Yes it does - is that OK? It's got a louvered cover on the wheelwell side, should keep debris from going in, there's an intake port on the bottom of the box also. I've found from previous safety inspections that it's required, just a good idea anyways I figure...Looking good! I don't recall if you told us, does the battery box vent into the fenderwell?
I've never installed one but I don't see why it wouldn't be fine.Yes it does - is that OK? It's got a louvered cover on the wheelwell side, should keep debris from going in, there's an intake port on the bottom of the box also. I've found from previous safety inspections that it's required, just a good idea anyways I figure...
Looks great!The grille finally made its way home from Mexico - since I flew home from Yuma, my fiance' brought it back with her to Washington, then I drove to see her and smugg - I mean - imported it to Canada.
Got it mounted in the grille shell and got it out in the sun.
Thanks, yes I'm a lucky guy, she's a hotrod girl too, this is her 27 TLooks fantastic Charlie.
Not to be nosey, but I picked up on something earlier...."fiance"? Congratulations!
