zzrodder
Still puttering along with misc small things...
Needed a mounting place for the fuse panel and grounds etc., also someplace to mount the gas pedal linkage, so I glued a steel panel to the inside of the firewall with PL700 adhesive (didn't want drill holes in it after filling so many and painting it....) Created a bellcrank to work the throttle, a cable will exit the firewall thru one of the cowl vent drain holes..
Also got the front window glued in with urethane, not without problems, cranked the screws down too much on the inside trim before the urethane set and cracked the first one
, oh well call it a practice run... + $$$
