Dr Crankenstein
No guide coat Dr. I’ve got some long battens as well as a 6 foot level that I will just lay on the bottom as I go along. The factory guidelines for bottom fairing says that a1/8 of an inch difference is acceptable. We will do better then that.
I may use my DA or go whole hog and pick up a cheap HF variable speed sander/ polisher. I will use a foam pad in it with 40 grit to begin and the go to my air board with 80 grit. About 3 hits of labor per side.
It doesn’t have to be perfect as I’m not building a 500 hp drag boat.
Thanks for the explanation. I had no idea how smooth you want, or need it to be.
