Old Iron
[cl[cl[cl
[P[P[P
[cl[cl[cl
[P[P[P
Looks Great ZZ[cl![]()
What gauge sheetmetal are you working with?
[P [P [P
I'm not making light of your talent, with the steps that you demonstrate to us it, take some of the mystery out of the process.
Thanks to you and all the members who do this, it expands our knowledge base and allows us to put out a better finished product.
You're going to have a heck of a lot of work in this car to make it look like you didn't do anything
Great work, looking good!
Thanks!
18 ga., a lot thicker than the original steel which is probably 21 or 22ga.
That's what I look for in the so-called reality shows about car builders, not a bunch of clowns that think they are actors.... I want to learn and see how things are built and made, but that seems to be to boring for the Networks...
Ain't that the truth - I guess I'm a sucker for punishment![]()
Could you make bumper irons that drops under the back panel then back up to the desired height, thus eliminating the need to punch holes in the back panel?
I have thought about that, the main issue with that is that they would hang down below the bumper and be visible from the rear. The bumper will sit 3/4" above the tailpipes , even with the bottom of the rear panel. Yeah, I know it seems nuts to cut holes in those nice clean corners, I do have repro rubber bungs to fit the irons through, so it does lend a stock look to it...... Still thinking on this one....
Agreed.I thought the same, that the drop-down irons would interrupt the clean lines you've got going on. You'll definitely figure out what will look best!
Agreed.
Besides, bumpers are overrated.![]()
If I recall, bumpers are required by law in BC.
Nice work, zz! Our '37 Coupe project need a new tailpan and I'm not looking forward to the job... can we ship the car to you?
