Got back to work on her car the other day. Got door hinges figured out and both doors mounted. Eventually I will figure out latches. Probably just go with bear claw latches like I did with my 31 chevy. Today, I started work on the cowl after taking a trip down to Great Falls and spending way too much on stuff I needed. Either way, 1” steel tubing for the inner cab bits, 2x3 3/16” wall tubing for the frame, and a sheet of 18ga and its time to get to work. Started with a scrap piece of tubing, I found the angle that the tubing needed to be bent, and cut the excess sheet metal from the cowl. Cutting the sheet from the cowl wasnt necessary but it will make putting the framework for it together a bit easier. The piece I cut for the frame work I butchered on accident but luckily I got enough that I should be okay for a little while(6, 24’ sticks.) Tomorrow I will try to make the front piece again.
