I made the plenum 300 cu. in., the same as the engine. Supposed to work good with a street/strip engine. I can add a spacer under the top plate to increase volume if needed. Added the end plates and the mounting flange for the top plate today. Also drilled and tapped the perimeter bolt holes. Will probably add an internal diagonal strip (as seen in one of the pics) to reduce liquid gas pooling. I share that concern with Skip.
Ford Autolite CFM by venturi diameter @ 3"Hg.
0.98 = 190 CFM
1.01 = 240 CFM
1.02 = 245 CFM
1.08 = 287 CFM
1.14 = 300 CFM
1.21 = 351 CFM
1.23 = 356 CFM
1.33 = 424 CFM
Remember that four barrels are flowed at 1.5 "hg.
So these flow numbers do not equate to 4V flow.
To convert divide by 1.41.
you may want to rethink this and make it a
treesome of 1.14's
600cfm 2bbl / 1.41 = 425.5cfm 4bbl
900cfm 2bbl / 1.41 = 638.3cfm 4bbl
if I remember correctly you had a 750cfm 4bbl on there
and it worked pretty darn good.
Also because I am super paranoid about bolts inside of an intake system,
it would help me sleep better if Iknew you were planning to safety wire
those bolts inside the plenum, or better yet since they go all the way
through the aluminum base, you could put metal pinch type lock nuts
on the bottom side. that way if they should come loose, they would not
aerate one or more pistons.
aerate lawn = good. aerate piston= BAD.
Looking really "HOT DAMN". Keep at it!!!
