This would be a good cheap start to some experamentation and ya could probably make a runner to sell out of all the parts and still have leftovers to play with
Looks like that swooping downtube thing was a henderson ace trait.Then when indian bought them out whent to a cheif style frame for economy I guess one frame casting fits all but just a little different for the four I know lots of stuff is interchangable with other models like scout tanks ,handlbars,footboards,pedals wheels ,forks,lights, fenders.A good idea that Ford or GM should be doing now one chassis fits lots of models...I know they do it to a point but they always seem to be trying to reinvent the wheel and now ya arent a mechanic you are a technician.
Good news: Virago final drive units are dirt cheap on ebay.
Bad news: The stock Virago final drive, is like the BMW,
it only has one U-joint. So Cook modified the input shaft
to accept a second u-joint. Most likely, his drive shaft is
2 stock Virago units welded together.
O.K. so couple one of those bevel gears directly to the end of the inline four then on the drive side of the bevel gear a doublerow sprocket and chain like a primary chain to a harley or other transmittion on the cluch side then on the opposit/sprocket end of the harley or other trans a chain to the rear wheel thats what I see.
the only other option is some kind of clutch set up on the end of the four to a bmw trans to a shaft drive but the sprocket and chain set up seems easyer as long as those bevel gears and chain hold up... ya follow me wish I could draw or use one of those cad type programs and make it a visual moving diagram.
I think If you had a single sprocket on the end of the crank,
and another on the input of the bevel box, they could be connected
with a double row chain.
I've got a Browning catalog somewhere, I'll look and see.
Then use a regular HD sprocket on the output to drive the trans.
You can probably get HD trans in electric, or kick, or both.
mmmm... still confusing need a simple diagram...[S there are harley trans or others with the sproket opposit the cluch side guess there are a few different ways to go intersting we found the bevel drive sets that could help with using a chain set up instead of a drive shaft ....
mmm.now i see most harley trans have clutch and drive on same side was thinking of my indian has the clutch on one side and drive on the opposite guess depends on what somebody has lying around....
Nice....may be a bit long looking but still cool could even go 6 speed and electric start. Mayby a little long looking....was thinking about fuel injected motor ...are the newer fours fuel injected... also wonder what would be the best scookum coupling to use. [cl[dr
When Confederate made their first bikes, they rotated the transmission forward 90 degrees( or was it backwards?).[S
Anyway, it saved them a couple inches on the length of the driveline.
With a little planning, you could run the shortest primary chain possible, to save a little length. I just drew it quickly, and out of scale.
A lot of the new bikes are fuel injected, but they are water coolers.
Carbs would be easiest short term, from there, Megasquirt/Microsquirt is one option.
For coupling the engine to the bevel drive:
two sprockets, one on each side, with a double row chain.
Price is right, and it allows minor misalignment.
