so after getting the rad mounted I wanted to start the motor again.felt good to actually pore gas and water in it. last time i started it wasnt able to run it a few minutes. I wired up a temporary ignition switch. things didnt go well at first when I pored water in the radiator it started leaking out of the back of the water pump. it had a hole rusted through on the back cover. got a new pump at oriellys . ok that problem fixed ,this thing should start right up . it ran just fine, just a few months ago. well it started ,popin and bangin and shootin fire out the headers. Oh damn whats wrong? checked all the wiring everything good. pulled the carb off and found gas under the power valve.not supposed to be gas there, and it was flooding the intake with fuel. replaced the power valve, bolted it back on and crossed my fingers. HOORAY it started right up and still sounds awesome. now that i can let it run I wanted to set the timing and tune it a little. the open headers are so loud inside my shop (must be getting old) I made some temporary baffles for them.
